ALternator belt pulleys not lining up
Nutty
Post by Nutty »
Ah, the joy of classic motoring..
Being in the process of changing the cam belt on Nutty I noticed that the belt pulleys on the crank shaft and water pump are not terribly well aligned, must be the best part of 2mm out. What is the consensus on creating a spacer and fitting that under the belt pulley of the water pump, good idea or is there something more sinister happening. The good news, so far nothing broken in the changing process. :groove:
The first tool invented was a hammer, the second a bigger hammer
BlackGT
Re: ALternator belt pulleys not lining up
Post by BlackGT »
When I fitted a new waterpump and pulley last year I had exactly this issue, I think it was the new pulley that has a slightly smaller offset from the pump than the old one. I added cardboard spacers under the pulley until it lined up correctly, has been fine since.
Seems common to have a water pump pulley not line up..
Better to fit a washer behind the pulley on the water pump instead of cardboard, the cardboard will get wet overtime and rust the bolts so you may move problem removing them next time.
A little smear of copper grease on the bolts will help taking it apart next time easier.
Nutty
Post by Nutty »
Thanks for the info.
