So i just tried to give my car some welly, and it jolted abit, and went i went to pull off she wouldnt go. She starts up fine but sounds like a miss fire to my untrained ears?
The can will roll on the clutch but wont drive, any ideas ? Please help!
Sent from my SM-G960F using Tapatalk
Please help
- C 20 CCO
Re: Please help
How old is the clutch? Have you done any work or had work done to the transmission or clutch?
kind regards,
Dave.
To be old and wise......
Dave.
- essextom
Re: Please help
carb flange?
Re: Please help
A bit more info will help...
Fuel injection or carb?
When was it last serviced and what was done?
Did you do or replace anything before it went wrong?
Any strange or extra noises?
Any air pipes fell off or electrical connection fell off?
Any fuel in the filter, you can only see if a carb engine...
How the fuel tank and fuel filler neck looking, any rusty holes? (shine a torch down the filler neck)
Re: Please help
carb flange.. rock the carb and look at the rubber mounting... yours is split... 15 quid on ebay and 30mins unbolting.. you will need a new gasket
