My GTII parcel shelf was replaced with a horribly heavy inch thick MDF sheet with some tights stretched over it and two 6x9 holes. Anyone know where to get hold of a cheap replacement shelf/a good material to adapt? Does a mk1 golf shelf fit?
Does the parcel shelf have a part number- I couldn't find interior bits like that on OEMEPC.
(The other part I was looking for was a rear speaker holder cup thingy, again wasn't on OEMEPC, but mine is missing one)
MK2 Parcel Shelf Replacement
Re: MK2 Parcel Shelf Replacement
Golf rear parcel shelf is different to Mk2 Scirocco, you need a Mk2 Scirocco shelf. I don't think you can buy them new anymore so might be worth posting up a wanted ad or ask in anyone breaking a car.
Same for speaker cup thingy..
Part numbers on this site...
https://volkswagen.7zap.com/en/rdw/scir ... -180000/#6
Shelf is 533867769F
Shelf is 533867769F
Found a shelf here but it has speakers in it... you could remove the speakers fill the holes and re cover the shelf?
viewtopic.php?f=5&t=21749
What material is the original shelf made from? I reckon I could knock one together out of something similar
It's a similar material to your floor carpet but I'm not 100% sure....
- essextom
parcel shelf is made of a fibre board/mdf style wood. easy to reproduce, just undo the tubes on the underside, remove the carpet and use the old one as a template, bit of black paint on underside and some acoustic carpet on top and jobs a fish.
blakey
Easy enough to do yourself, there is also this option to make it a bit easier, but not as cheap:
https://newtoncomm.co.uk/collections/sc ... -board-kit
'89 Sapphire Scala Inj.
Member No. 1455
Member No. 1455
