need a high pressure fuel filter?
just so happens halfords do a metal canister filter that has normal 8mm hose tails!
so you can just push on some 8mm rubber hose with some jubilee clips.
only problem with the mk3 filter is the connections are made for plastic pipe quick connections and not for rubber hose unlike the above.
with a halfords trade card the filter was £8
