Sorry, not a Scirocco question
Village Idiots
Post by Village Idiots »
Does anybody know if modern engines have a sensor which would switch the engine to limp mode if desperately in need of an oil change?
mr.brown
Re: Sorry, not a Scirocco question
Post by mr.brown »
Oil level sensor but I've not heard of an oil quality sensor. That said, some engines - specifically the 1.6 Ford/Peugeot/Citroen engine from 06 onwards had a very fine tolerance for oil quality and would destroy the turbo and then the engine. First symptoms were going into limp mode when the turbo started to disintegrate - presumably the ECU knew there was some kind of issue.
If your car is in desperate need of an oil change I would change the oil and see if it make any difference, regular oil changes is important to any engine.
Jack92
Site Admin
Post by Jack92 »
I was driving a new Astra recently and it put itself into limp mode as it needed a service, once the service indicator was reset it was fine. So could also be software related in your case
Jack
South East
VW Scirocco Scala MK2 1.8 Inj
Jaguar F-Type
