Another temp sensor problem
Re: Another temp sensor problem
Some more info etc here, Briano1234 knows his electrics, he's answered a lot of problems etc on the Mk1 golf forum.
http://volkswagenownersclub.com/vw/show ... ater-Gauge
http://www.toplessrabbit.com/forums/vie ... =27&t=2042
More guides etc here.
https://vwgolfmk1.org.uk/forum/index.ph ... -of-things
it does have a thermo stat in it doesnt it?
if it didnt have a thermostat in this might be your issue
Yolandi2
Post by Yolandi2 »
had a check last night and yes there is a stat in and it does work as intended (opening at 87C)
I guess the problem is electrical then, ill pull the clocks and check the regulator today
1990 mk2 GT2
Yolandi2
Post by Yolandi2 »
Checked the regulator, just under 10v, like 9.95v so I think that's good, maybe I have the wrong sensor?
1990 mk2 GT2
