Hi and welcome..
You may want to use the search function in the title bar and try "20v" or "1.8T". There is quite abit of info knocking around on this site. I can give you some more detailed pointers if you need, or should i say "I can try!!"
In some of the other threads other members have asked similar questions and I am sure there is a few helpful links embeded in them too.
Here is a good starting point for a Guide to carrying out this conversion. Its based upon a Mk2 Golf, but I presume the only difference would be the engine mounts and maybe driveshafts.
http://www.qpeng.com/conversion_guide.html
My car is running the 280mm G60 brakes on the front, mk2 golf 16v rear disks, and upgraded braided hoses all round. It stops ok, but I am defo going to go for the servo and MC upgrade when i get round to it and change to some fast road pads.. G60 brakes are the same as early Mk3 GTI/VR6 brakes (not the later 288mm versions found on cars >96 i think), its just the disk that is different. You will need some adaptors to fit them tho i think. I have some of these calipers if you need them.
