87 Black GTX
- scrappy1382
Re: 87 Black GTX
looking good pal. funnily enough the 20vt has the golf 1.3 cable too. didnt realise untill i checked the paperwork that came with the car.
ideas on time/date wise on getting her running ? nationals is quickly creeping up !!!
Scirocco Shane
84 Havanna Brown Storm -
Re: 87 Black GTX
hoping that a few more full days on it and itll be ready to start, then its a case of setting it up and testing
got a feeling im going to need a different starter and possibly alt to connect to the loom
Resto Rocco
Re: 87 Black GTX
Good on ya. Really nice find! I'm in to see where this goes. Im also looking at either a 20vt or letting my aggression out with an RB25Det
- scrappy1382
Re: 87 Black GTX
Popped over to see blackgtx today, gave a helping hand with a top mount and exhaust system
Sent from my Moto G Play using Tapatalk
Scirocco Shane
Re: 87 Black GTX
bit more progress with thanks to scrappy who swung round and helped out
did one top mount and we jacked the back up and got the rest of the exhasut fitted
Re: 87 Black GTX
still chipping away at this, got some clearance issues at the mo
it all looks ok
dizzy fouls, should be able to rotate it but there are only 2 positions to bolt it in
had to use a flat brake res cap as the induction arm sits on it and the coolent hose wants to go through it at the mo
it all looks ok
Re: 87 Black GTX
been a complex build so far using a combo of parts
abf engine
abf 45° dizzy
dx fly, cluch and gearbox
16v inlet and supports
16v induction arm
abf throttle body, 16v cable holder
golf 1.3 throttle cable
dx airbox
abf isv
16v injectors and lines
16v loom ecu and knock box
16v knock sensor
16v lambda sensor
scirocco abf 421 manifold and exhaust
polo g40 master cylinder vacuum pipe
polo cl oil breather hose
all this because i wanted the engine to look natural in the bay and not hacked in. no idea on what sort of power it will produce
abf engine
abf 45° dizzy
16v induction arm
dx airbox
abf isv
16v knock sensor
16v lambda sensor
- scrappy1382
Re: 87 Black GTX
looking good buddy. like everything, it all takes time and patience. your doing a good job. keep going with this.
Scirocco Shane
Re: 87 Black GTX
fitted this also, really tight fit. atleast vw had the sense to make it from a flexible plastic
Re: 87 Black GTX
Petrol tank out, discovered when doing the exhaust that the tank leaks from the lip. New ones not in yet, need to foam the top and will probanly paint the heat shield now i have time. No nationals this year
Re: 87 Black GTX
This was from a few weeks back, pulled it out to clear the garage or scrap
Not got the mew tank in yet, that'll have to wait a while. Need to swap the suspension over too then adjust camber and tracking
steve bain
Re: 87 Black GTX
Can buy them heresteve bain wrote:I do like your wheels.....
http://www.bulletwheels.co.uk
Mine are 8j 185 50 15 and 9j 195 50 15. Ill be getting new ones when its running
