Hi all,
Whilst clearing out my stock of parts, some not seen by me for some time!! I came across this rear original nos back box for I believe a mk2 scirocco the only problem is I cannot for the life of me cross reference the part number
TYP NR 533 119 C
Made in west germany so gives u an idea of how old it is I've included a couple of pics so hopefully someone can help
Cheers Rod
Oem exhaust
mr.brown
Re: Oem exhaust
Just from looking at the mounts it's for a later mk2 with spacesaver spare wheel.
If the back pipe is as long as it looks then it's for a body-kitted model.
Carb or injection depends on the diameter of the inlet pipe.
Re: Oem exhaust
Show us your tail pipe !! If it sweeps up to top left as seen from the back of the car - it will be from Scirocco Mk2. If it does a little kink and comes out fairly parallel to the silencer - then it maybe a from a Golf Mk1 Cabrio (later 1.8 cars). Haven't checked the number however ??
Re: Oem exhaust
If the code starts 53 ( as it does) then it's a scirocco part.
Re: Oem exhaust
Re: Oem exhaust
Hi guys thanks for the replys I'll get a picture of the tail pipe at the wkend with it unwrapped
If I remember correctly the chap I got it from was a head VW mechanic and said it was for a scirroco as per the 53 but have never unwrapped it until now, it's been tucked away for so long.
Thanks again for all comments and help
