upgrading front discs
Hi i wont to upgard my font Discs too 256mm,does the GOLF MK2 GTI BRAKE CALIPERS, DISCS work, is there anythink els i need to get, thanks
Alpine
Alpine
- bengould
Re: upgrading font dish
I don't think the mk2 golf calipers fit. Mk2 Scirocco 16v or some early audi ones do, not sure of the exact model.
The mk2 discs do.
You are probably best replacing the flexi hoses and have some spare copper lines too as the old ones will probably break when you remove the union to the flexi pipes.
Another route is to use corsa/tigra calipers, carriers & flexi lines, shouldered bolts (M10 thread with 12mm shoulder) and mk2 golf 256mm discs.
Ben.
The mk2 discs do.
Ben.
Hi ben thanks for the info,just got theres off ebay ,hope they right ? 2.0 256mm brake upgrade Nova Corsa Tigra Astra GTE GSi C20XE C20LET redtop 16v,it come with calipers, carriers, vented discs and pads,i seen some (M10 thread with 12mm shoulder)but not sure which be the right one,or can you give me a link to the right shouldred bolts,heres a picture of the calipers, carriers, vented discs and pads,bengould wrote:I don't think the mk2 golf calipers fit. Mk2 Scirocco 16v or some early audi ones do, not sure of the exact model.
The mk2 discs do.
Ben.
big thanks for any help,
chris
- bengould
They look exactly like mine, and from that description they are what you need. I will dig out a link to where I got my shouldered bolts from later today.
Ben.
Ben.
- bengould
I used these, with a shakeproof washer and a bit of threadlock.
http://www.wdsltd.co.uk/product/3244/so ... ic-wds-615
Part No. 615-M10-12-25
Ben
Ben
Ben thanks bro sound good to me,i wait for the link and were did you get your flexi hoses ? till latermr alpine92 wrote:Hi ben thanks for the info,just got theres off ebay ,hope they right ? 2.0 256mm brake upgrade Nova Corsa Tigra Astra GTE GSi C20XE C20LET redtop 16v,it come with calipers, carriers, vented discs and pads,i seen some (M10 thread with 12mm shoulder)but not sure which be the right one,or can you give me a link to the right shouldred bolts,heres a picture of the calipers, carriers, vented discs and pads,bengould wrote:I don't think the mk2 golf calipers fit. Mk2 Scirocco 16v or some early audi ones do, not sure of the exact model.
The mk2 discs do.
You are probably best replacing the flexi hosesflexi hoses and have some spare copper lines too as the old ones will probably break when you remove the union to the flexi pipes.
Ben.
chris
- bengould
Think it was either off ebay or local GSF. I used the standard corsa rubber flexi. The end to the copper line is a standard fitting, just the caliper end is different.
Braided hoses would be better though if you can get just fronts instead of a full set.
Ben.
Ben.
cool ben iv just order the shoulder bolts,and yes i get some braided hoses full set as im doing back brakes toobengould wrote:Think it was either off ebay or local GSF. I used the standard corsa rubber flexi. The end to the copper line is a standard fitting, just the caliper end is different.
Ben.
Hi ben could you do me a favour and give me the length of your Braided hoses,i going to see if i can get some made up at the same size,with same fitting for the calipers,bengould wrote:Think it was either off ebay or local GSF. I used the standard corsa rubber flexi. The end to the copper line is a standard fitting, just the caliper end is different.
Ben.
- bengould
I didn't use braided. Just standard corsa rubber ones, they are plenty long enough so I would assume corsa braided ones will also be fine.
Like these...
http://pages.ebay.com/link/?nav=item.vi ... 54&alt=web
Ben.
Like these...
Ben.
thanks ben,as soon as my calipers are here,i be ordering a setbengould wrote:I didn't use braided. Just standard corsa rubber ones, they are plenty long enough so I would assume corsa braided ones will also be fine.
Like these...
Ben.
Re: upgrading front discs
Just to update that all the work done know and if anyone wont to upgrade this what you can do,big thank to Ben,
Looking good. Can you still fit the standard 14" wheels?
yes but i need to put spacers on,iv gone for 10mm as back off the tyre rubbing on the coilover,just hoping 10mm be OK,mark1gls wrote:Looking good. Can you still fit the standard 14" wheels?
that looks well nice how did you clean up the calipers so well?
i need to do mine next year
