Rear wiper not working
unknownmale
Post by unknownmale »
Rear wiper is not working, rear washer is working, as are the front wipers. I don't have my haynes with me, but from memory don't these share a fuse?
If so, does this mean i have a bad motor?
Will crack the multimeter out this weekend, but wondered if anyone had come across this?
- David
marcus
Re: Rear wiper not working
Post by marcus »
Before you do that, make sure the nut securing the arm to the motor spindle is tight, mine wasn't working and that's what it turned out to be.
1985 GTL 1.8
And a good blow around the base of the wiper stalk as the little brass connectors can get alsorts of fluff etc over them and it stops them making contact.
