WAXOYL removal
Re: WAXOYL removal
If it was me, I think i would try a heat gun and some blue roll to soften it and wipe it off, then try something like wd40, petrol, brake cleaner or thinners to remove the rest. Be aware of damaging paint with chemicals and setting fire to stuff
Re: WAXOYL removal
Where is the waxoyl and why do you want to remove it?
Re: WAXOYL removal
It was done in 79 its in the engine bay on the sills ( outer ) in most places. Rear valence ( outer ) Front valence ( outer ) . I have got it off the places i need to weld . Its done its job
Re: WAXOYL removal
I used one of these on my angle grinder which worked well.
Re: WAXOYL removal
If you need to weld, the waxoyl obviously hasn't done it's job ;DWaddy wrote:It was done in 79 its in the engine bay on the sills ( outer ) in most places. Rear valence ( outer ) Front valence ( outer ) . I have got it off the places i need to weld . Its done its job
I found a disc cutter works well to remove it. Soon sets fire to it, rapidly folllowed by 2 more cars in the scrapyard. Ooops!
Re: WAXOYL removal
May be a toffee wheel will shift it quick? Does well with glue residue
insanecreations.net
insanecreations.net
