G Beats wrote:OK I see James.It did not get damp on it or moister in the air when it was drying out ? As it does rain a lot in this country.And all so you have the rolling shell outside under a cover garage.
i think you may be right geebeats, some areas did get damp from condensation.
but i found out after that the main problem was when i sanded back the paint i used paint prep wipes to clean the body before spraying and i didnt leave enough time for it to evapourate off the body before i sprayed it with primer.
i found this out by wiping a panel then spraying a small bit and it reacted straight away.
so i learnt my lesson and started again leaving plenty of time before spraying it, so now i have a good base to respray the main coats on again.
this is how she looks now
i also painted the anti roll bars which came out nice
and the clampy bits
