Anti roll bar upgrade
- essextom
My anti roll bar seems to have been used as a jacking point and is a little bit bent. ive seen that eibach do an anti roll bar kit but it's a little bit more than I want to spend. Has anyone got any experience with a stiffer one, or knows of a cheaper alternative? Cheers.
Tim_R
Re: Anti roll bar upgrade
I'm doing a little bit of second guessing here as you don't say which end is bent. However front ARBs should have a slight downward bend in them towards the centre of the car to allow clearance for the exhaust pipe, I wonder if yours has been removed and refitted upside down at some point?
Rear ones are pretty much straight from side to side, I think I've still got a standard rear one in my garage somewhere if needed. Eibach ARBs are a good upgrade if you are still running standard springs or fairly soft lowering spring (like eibach's pro kit) as it stiffens up the rear a lot more and gives a sharper turn into corners. I think H&R used to do ARBs for the mk1 chassis as well, although i seem to remember they were more expensive than Eibach.
Scirocco GTII 2L 16V
Mk2 Golf Gti 8v
T4 Transporter 2.4D LWB
Mk2 Golf Gti 8v
- essextom
Thanks for the reply. It's def been damaged it bends up near the inner mount but only on one side. I've got wietec tx adjustable coilovers to be fitted, so I can make the ride quite hard. Think I'll just fit a standard one and replace at a later date if I fancy it. Are there thicker standard ones?
mr.brown
16v ones might have been thicker but obviously hard to get hold of. I have a standard one here with Powerflex bushes if you fancy a p/ex for the other bits.
- essextom
Yeah that might work mate. Fancy meeting on sun 19th at cobham services?
mr.brown
Sounds good
- b5byt
I've just fitted front and rear H&R ones with all black series polybush kit but can't say how it feels yet as the car is not running.
1984 Scirocco Storm Cosmos Blue < Body has really had it, if you need parts off it let me know < Going.
1986 Scirocco Scala (Rocco-Jocco's old one) Having some life put back in to it
2001 Carbon Black E39 M5
2008 Carbon Black E60 M5
- essextom
You'll have to let me know if it's worth the £ when it's on the road.
