I've got a set of Pole Position's I want to fit into a MK2, I have the seats and the Recaro side mounts.
What is the deal with the subframes? Do Recaro make a direct fit adjustable subframe? Or is it going to be a custom thing?
Recaro Pole Positions in MK2
- b5byt
1984 Scirocco Storm Cosmos Blue < Body has really had it, if you need parts off it let me know < Going.
1986 Scirocco Scala (Rocco-Jocco's old one) Having some life put back in to it
2001 Carbon Black E39 M5
2008 Carbon Black E60 M5
mr.brown
Re: Recaro Pole Positions in MK2
Going to be custom. If they're side mounted the usual way is to weld in a couple of cross bars - see post no.66 on this page
http://www.clubgti.com/showthread.php?1 ... -P54/page3
- b5byt
mr brown to the rescue again !
Hmm, is there anything that would let me slide forwards and backwards as obviously these are fixed back so no adjustments on the seat its self..
Thanks !
Thanks !
mr.brown
Again, it's a question of customising. Every seat manufacturer makes a sliding subframe - basically a pair of runners and a handle to link the two. You bolt the lower side of the runner to the fixed subframe and the upper side to the seat (or in your case the side mounts).
The picture on the right explains what I mean
- b5byt
Thanks, so next question, did they ever make scirocco subframes or was it just a case of use the MK1's instead?
mr.brown
I think that anyone who ever sold Scirocco subframes were just repackaging mk1 Golf subframes. The problem is that the mk1 Golf ones are too high - add on the extra height of the slider and side mounts and your head will be jammed into the roof.
VW did an option for electrically operated Recaro seats for the Mark 2, but I do not think the subframes are still available.
Konig purportedly do a Scirocco specific subframe.
- b5byt
There's a pair of Recaro - Scirocco Mk2 subframes on eBay.de at the moment, I have sent over a message.
Thanks for the input guys
Are the Konig ones still available ?PeteGLi wrote:VW did an option for electrically operated Recaro seats for the Mark 2, but I do not think the subframes are still available.
