Left side lights stuck on!
91 scala. Came home work, roco in drive, lhs side lights on. Had pull fuse just, dark and heavy rain. Any ideas folks?
Re: Left side lights stuck on!
You may not be aware but the cars came with parking lights, with the ignition off if you have the indicator stalk switched to left or right it makes the side and tail lights come on that side.
Hopefully it's this.
Shame it isn't an easy fix then! Could be the stalk shorting out?
