No sparkplug spark
markchez
No sparkplug spark
Post by markchez »
Hi
Got a storm
Have no spark from disi to spark plug
Got spark to disi
Changed all leads caps rotary arm
bought new old disi
Tested hall sender and tci unit I think correctly
Help
marcus
Re: No sparkplug spark
Post by marcus »
If you're getting a spark to the distributor then the coil, hall sender and TCI-H unit must be in working order.
If you've changed the leads, cap (double check the spring loaded carbon centre pin) and arm the only thing that leaves (other than the plugs themselves) is the engine earth strap, goes from back of cylinder head to bulkhead.
1985 GTL 1.8
How are you checking for spark?
