Mk1 distributor issue
2 pipes coming out the vacuum unit were do they go there just hanging in engine bay
Mk1 storm
Mark
Mk1 storm
Mark
Re: Mk1 distributor issue
A picture would help mate?
To dark at the moment but I'll get some pictures tomorrow as I'm driving my Mk1 this week as the weather is finally dry
The hose you are holding connects to the pipe that is under your left hand, just above the white thingy.
Hi
Is that both hoses in my hand or does one go there and the other one somewere else
Mark
Mark
The shorter pipe goes to the vacuum hose that has a screw inserted! The longer one goes to behid the manifold.
Yes, on the inlet manifold/throttle body.markchez wrote:Hi
the long one to the second pic is that
Mark
Do you now part number for the broken white part the tube goes into trying to order from vw heritage.
Mark
Mark
You may find that this part is now obsolete. It is no longer on VAGCAT, but try your local VW dealer for the part number and check the usual sources.markchez wrote:Do you now part number for the broken white part the tube goes into trying to order from vw heritage.
Mark
The part that has broken off was supplied complete and forms the vacuum off the brake servo.
