White speedo/clock vinyl on eBay
scirocco-monkey
Re: White speedo/clock vinyl on eBay
The chap who makes these dial kits is a very good friend of mine, He recently made me a purple set for my Scirocco. They are very well made and he can do dial kits for most cars.
scirocco-monkey
The guy who makes these kits is up my house now and he said he does the 160mph kits.Any more info,give me a shout and i'll pass on his details to you.bengould wrote:Hi,
You've just reminded me. I was after some of these a while ago. Anybody know if they are available for the 160mph clocks, I could only find 120 or 140 when I was looking.
Ben.
Cheers.
Rich.
Just wish my Scirocco went to 160 mph
- bengould
Thats good to know cheers. Might be a while now but I'll give you a shout when I'm in need and can be bothered to strip the dash down again.scirocco-monkey wrote: The guy who makes these kits is up my house now and he said he does the 160mph kits.Any more info,give me a shout and i'll pass on his details to you.
Cheers.
Rich.
Me too. Shame it's just the numbers on the clocks.mark1gls wrote: Just wish my Scirocco went to 160 mph
Ben
Niall
Any idea what bulb I need so I can get a blue tint as opposed to the ugly green/yellow that they currently have?
Niall you need to remove the green tint that hides under the white plastic bulb holder. i managed to pull mine through the hole the bulb goes into and bought blue led bulbs to go in instead but they were cack (wernt bright enough), so i prised the plastic bulb holder off a fitted a red neon tube inside it and glued it back on. looks much better and brighter and can be dimmed using the dimmer on the headlight switch.
i used tubes like this but red.
http://www.ebay.co.uk/itm/Revoltec-Shar ... 2c63c7b03c
G5 VWS
I did this by removing the green film under the white bulb holder. I made the slot bigger with a dremmel with a cutting disc and put blue led in. Pretty easy couple of hours work
Niall
Looks great, so are they actually those tiny bulbs you get in Halfrauds or LED strips from ebay?
G5 VWS
They were these off eBay. They go in the original bulb holders. You get a pack of 5 I think
http://m.ebay.co.uk/itm/310311081271?nav=SEARCH&sbk=1
