This has only happened since installing my sub, which I guess must be at fault, especially since it appeared to work alright once I had removed the sub's power cable from the battery. So why could this be/ what have I done wrong?
The sub was wired in by unscrewing the bolt on the battery terminal and sliding the ring connector on, then bolting back up:
![Image](http://i851.photobucket.com/albums/ab75/crashbanggg/86B165C7-38A3-499D-9E0C-A3C3E70EC862-2351-000001F484CDD84D_zpsa66c3a7f.jpg)
And the amp for the sub is earthed as such (If that would have an effect?Though the sub/ amp work fine when the car is going):
![Image](http://i851.photobucket.com/albums/ab75/crashbanggg/143B6B21-36DF-4B83-9457-EA973750C44D-2351-000001F47399CAE9_zps5bb94a7b.jpg)
Oh, and the alarm randomly went off whilst sat on the driveway (I have never actively turned the alarm on, im not even convinced the motion sensor is connected)
What have I done wrong?!
Chris
