Hi guys, anyone have any info on the 4+E gearbox please.
4+E gearbox
Re: 4+E gearbox
Lots of info here.
http://www.brokevw.com/
Re: 4+E gearbox
Site seems to be down, but thanks.
I'll try it again later
Re: 4+E gearbox
That sites a bit complex for me.
Any info in laymen's terms ?
Re: 4+E gearbox
Its a gearbox. Or is that too simple?
what is it you want to know about them?
Re: 4+E gearbox
Ha, well I've heard the E gear isn't really a 5th like normal gearboxes, and is really only for around town ?
How should it be used?
Do I only use 4th on the motorway?
Re: 4+E gearbox
The E means economy, it is for cruising i.e motorway driving!
Re: 4+E gearbox
You'll find when in 5th (E) you will not be doing many revs at 70mph (about 1,750rpm) in a Gti gear box at 70mph you will be a 3,500rpm. The Gti will be more responsive at 70mph, with your gearbox you will need to change down to 4th to accelerate then go back into 5th(E)
The plus side is you will use less petrol with 4+E at motorway speeds.
Re: 4+E gearbox
Great, thanks guys
