Car is doing what it says on the tin really - starts fine when cold and idles ok. However once it gets up to temperature the idle drops to 500 rpm or less
It was running fine until the other day. It had been standing on the drive for about a week or so, before I stopped using it she ran perfect, started her up the other day and the idle was mega low once warm. Nothing had changed so I don't really know what could be wrong.
My thoughts are fuel starvation or maybe a gunked up crank case breather (it's not blowing as hard as the one on my Golf). Is there anything else I can trouble shoot? The choke is wide open when hot and I've got all new vac lines from a few months ago. I'm a bit stumped :(
Cheers,
Josh
*edit
I should probably add, it's a 1.8 MK2 Scala on a Pierburg 2E2 (I know - boo, hiss etc.)
