I decided to have a look inside my fuel tank the other night, and this is what I found:
As you can see there are a few flecks of rust, and my tank is corroding slightly. I've had cutting out issues previously, but a new inline fuel filter and a change of carb seems to have sent that problem away for a bit.
But back to my original question, how severe is the problem I've got from the amount of rust in the tank? I have a 3 series filler neck and inline filters are cheap, am I likely to be able to keep on top of the problem just through a new neck and filtration, or is that enough sediment to warrant cleaning the tank out. In all honesty I don't fancy the hassle of dropping the tank
Cheers,
Josh
