gearbox question
jond
gearbox question
Post by jond »
just a quick one when the car is running and you look in the engine bay i can see a small hole ontop of the gearbox through which i can see either the flywheel or clutch spinning should there be a cover there and if so where can i get one thanks
bengould
Re: gearbox question
Post by bengould »
Hi,
Yes there should be a cover. I think I have seen them on ebay.
Ben
Or go down the local scrap yard there should be plenty floating about on old audis and vws.
Yeah, should be a little green cap. Think they're only a couple of quid new from Vw
jond
Post by jond »
thanks if i go to vw are they the same as golf mk2 or anyone got a part number
bengould
Post by bengould »
jond
Post by jond »
great I will get one ordered just out of curiosity what is it I am seeing spinning round inside plus whats it there for in the first place
marcus
Post by marcus »
It's the flywheel - it's so you can see the ignition timing mark.
1985 GTL 1.8
