MK1 Front Indicator lenses
Moderator: Scirocco Register
no price? assume deletion, lock or worse. Daily bumps? No thanks.
Pair of original front indicator lenses complete with backing rubbers. These have not been in the open for 20 years so they are not faded at all. However , sadly, they are not mint - the N/s one has a 50mm strip broken off the lower inner vertical edge and the O/s one has a similar strip off the bottom inner edge; but they are not cracked and are completely water tight; with perfect silvering while the pair of backing rubbers are mint £35 posted.
