And so suddenly we're in September, how on earth did that happen?
Last weekend was the ever brilliant Vw Action at Santa Pod. Unfortunately sporadic rain came hammering down on the Saturday cancelling the racing for most of the day and sending us all scuttling for cover but it didn't really stop the fun.
In the run up I'd had the preceding week off so busied myself with getting the car ready but with three days available I ended up doing a few more bits than I anticipated. Always fun but risky as it's normally those "small jobs" that end up with me arm deep in wiring crying into bottles of wine and shaking my fists at Odin.
First up was to strengthen up the rear parcel shelf supports. On the Golf these are removable and replaceable unlike the rocco, seems like a small thing but I like it. Means it's easier to get the extra space should you need it (especially when stripping them down) and they're easy to put back in. The down side is that after 30 years they're often brittle.
For some reason I only got photos half way through the process but take my word for it, once they were finished you wouldn't notice the difference.
After this it was a quick rub down, marry up the holes and drill new ones and spray it all.
Also started on the speaker pods. Again, 30 years of abuse have taken their toll. Will get more pics over the weekend if I remember.
This one was a little more complicated and I had to build everything up slowly, rub it all back and redrill everything.
Re-glued all the struts and put a layer of fibre glass on the joins so hopefully it won't happen again. Quite randomly I picked up another set from a lad at Action which had the same problem.
All this brings me to the stereo. Couple of choices: Vintage looking stereo or a rebuild. Need to look into the practicalities of both. The off the shelf ones are ready made and do everything I need but apparently the sound quality isn't fantastic. To be fair, will I actually notice?
The other choice is to send an original unit off for a complete refurb. This is considerably more expensive but I can state the kit and outputs that I want.
For the time being I've just bunged the house Bose unit in. Brilliant piece of kit anyway and solved the issue for the short term.
Only other problem was the water hose splitting and pishing everywhere. Luckily I was only 200 hundreds yards down the road and the split was near one end. Managed to get a new one but just cut the end of and stuck it back on as a quick fix. DId another 250 miles so clearly wasn't that bad.
So now everything slows down a bit.
Won't be storing it over the winter like I used to with the other car but it'll be off the road for a bit. Going to lay all the wiring for the stereo equipment and another 12v outlet, while I'm there I may put some sound deadening down but that really depends on the state of the bodywork.
After that it's starting work on the engine bay. It needs a bloody good clean so I can properly look for leaks then give it a proper service and change the gaskets. Also got a load more powder coated parts that'll start replacing the tribute to Bob Marley under the bonnet.
