New Scirocco Owner
Moderator: Scirocco Register
h11poc
New Scirocco Owner
Post by h11poc » Wed May 19, 2021 4:07 pm
Hello to you all. I recently bought a Pearl Green 1991 GTII . It was on Ebay last week so some of you probably saw it or know the car.
So far it seems solid with Fuel tank , fuel filler neck and rear mounts all fine. There are a few jobs to do as expected of which rebuilding the original 2e2 carb is the first as the auto choke is hanging out separated from the carb. There are electrical issues too of which one is no interior lights (checked door jam wiring and bulbs which are fine except for no boot light bulb.
This is my second Scirocco , my first was back in 1990/1991 when i owned a mint Mk1 GLi in blue (light blue)
I've been reading the forums and using the search facility so thank you so far for in-depth knowledge as it's helped me a lot. I will have some requirements for parts but I'm going to carry on searching for no on this forum just in case the fix('s) is/are out there.
Paul
Re: New Scirocco Owner
Post by GTXTRA » Thu May 20, 2021 12:04 am
Welcome Paul!
RussGLAuto
Post by RussGLAuto » Thu May 20, 2021 7:20 am
Hi Paul,
Welcome to the forum. I did see this on eBay, looked tidy, to find one with the original Pierburg carb is becoming a rarity these days. Try and keep it if you can. Lots of rebuild kits available. If you need a specialist, Google Bromyard VW.
Russ
Weekend Wagon - 50k 1982 Mk2 Scirocco 1.6 GL Auto - Diamond Silver
Other Half's Wagon - 2008 Mazda 2 1.5 Sport - Cosmos Blue
h11poc
Post by h11poc » Thu May 20, 2021 8:07 am
Thank you GTXTRA and Russ.
