Wanted- Warm up regulator fuel line - DX
Moderator: Scirocco Register
Hi (my first post here for the record)
Recently got an 88 scirocco gtx, I believe the previous owner was on here.
Anyway, I guess I got a bit excited as I broke the fuel line going from the warm-up regulator to the K-jetronic fuel metering head. I've been doing a bit of research but have been struggling to find anyone who sells it. Again I've only been researching for a bit but I believe the code for it is 067 133 655 B if that helps.
If anyone has any info you can reply on this thread (ill check it regularly for a week or so after posting)
Feel free to correct me if you think I'm incorrect I appreciate the info
Re: Wanted- Warm up regulator fuel line - DX
Found on eBay but looks like it will need to carefully removed from the WUR, soak it with plenty of Plusgas or you may have the same problem…
https://www.ebay.co.uk/itm/374184449207 ... SwMHdhrL9Y
I don’t think you can buy just that pipe new anymore so search for second hand, Mk1 Golf cabriolet has the same set up to widen the search. As you have the part number it maybe worth a call to a main dealer to see if they can get one?
The new pipe comes as a set (check it’s the right size before ordering)
https://www.classic-vw.co.uk/mk1-golf-g ... 4912-p.asp
Here but parts in Lithuanian
https://www.ebay.co.uk/itm/313832345111 ... Sw31JfgzuZ
Postage seems rather expensive on this line..
https://www.ebay.co.uk/itm/313832339313 ... Swc2dfa1NO
Those should be perfect I've made an offer on your first link
thanks for the help I guess I wasn't searching for the correct things on eBay
once again thank you
If you can get the fuel lines off the WUR and don’t need a spare WUR then you can sell it.
I’ve seen them go for silly money to the Mk1 Golf boys.
https://www.ebay.co.uk/itm/165580186347 ... Sw4DBilPUt
Remenber that Golf and Scirocco are not the same.
The metering head is on the right with a Golf and on the left with a Scirocco so there are differences in lenght for the fuel lines.
Better measure and compare length first.
Joost
https://scirocco-delen-eimers.nl
Joost
only on the 16v. 8v's have metering head same side. so all lines are the same.Blueshark wrote: ↑Mon Aug 01, 2022 7:39 amRemenber that Golf and Scirocco are not the same.
Joost
82 mk2 gti - 88 mk2 scala 20vt - 84 Mk2 GL auto - 93 GT2 2.0 8v crossflow - 91 scala - 84 Tropic - 89 scala - 88 GT
Sorry to say but on the 8V's the metering head is on the left side aswell, if not it is from a Golf.essextom wrote: ↑Mon Aug 01, 2022 9:45 amonly on the 16v. 8v's have metering head same side. so all lines are the same.Blueshark wrote: ↑Mon Aug 01, 2022 7:39 amRemenber that Golf and Scirocco are not the same.
Joost
Scirocco 8V https://volkswagen.7zap.com/en/rdw/scir ... 133-48000/
Scirocco 16V https://volkswagen.7zap.com/nl/rdw/scir ... 133-48050/
Joost
From the outside of the a UK DX with the bonnet open and facing toward the car the metering head is most definitely on the right
Danny
The two WUR fuel lines (067133655B and 067133657B) are the same part number for the Mk1 Golfs with K-Jetronic and the Mk1/Mk2 K-Jetronic Sciroccos. The airbox and fuel distributer are located on the left side of the car (if you are sitting in the car).
Joost - you may be thinking of the Mk2 Golfs - VW moved the airbox and fuel distributor to the right side (as viewed from inside the car) on those models. For those cars the part numbers are different - 027133655B and 027133657B.
Mk2 Scirocco Storm
Mk3 Golf GTI VR6
Mk3 Golf GTI VR6
mk1 golf is the same as rocco.Blueshark wrote: ↑Wed Aug 03, 2022 8:52 pmSorry to say but on the 8V's the metering head is on the left side aswell, if not it is from a Golf.essextom wrote: ↑Mon Aug 01, 2022 9:45 amonly on the 16v. 8v's have metering head same side. so all lines are the same.Blueshark wrote: ↑Mon Aug 01, 2022 7:39 amRemenber that Golf and Scirocco are not the same.
Joost
Joost
mk2 has metering head on other side
I’ve got a set of pipes here, you can have the lot for £25 plus postage?
