will ford wheels fit a scirocco
will 4 stud ford wheels fit a vw or is it a different pcd
what other manafacturers wheels fit
thank you
thank you
- The Autoad
Re: will ford wheels fit a scirocco
Any 4x100 bolt pattern wheel will fit in theory. The considerations need to be made around wheel ofset and centre bore size. If the centre bore on a wheel is smaller than the Scirocco 57.1mm then the wheels will need some machining, which may compromise the integrity of the wheel. Larger bore sizes are easier to fit, as a spigot ring can be purchased/machined to make the wheel fit the hub snugly and safely.
Which other manufacturers fit? take a look here http://www.carlsalter.com/wheel_fitments.html
If you want a wheel with a different stud pattern you will need to purchase adaptors.
I think Ford PCD is different... 4x112?
A lot of older ford wheels are 4x98 and will fit roccos with wobble/wibble/whatever you call them bolts ok :)
- filmidget
They would have to be very old - 4-stud Ford have been 108mm for quite a while.
- Ryan
FIAT/Alfa's?Slugga wrote:damn, sorry, what am i thinking of thats 4x98 then?
Some Vauxhall/Opel wheels fit.
- Junglist
There are some websites and forums with full listings of makes and pcd's. Ones I know of same as 4 stud vw include:
Vauxhall, Renault, Nissan, some Alfas, lancia deltas, austin/rover, BMW, audi, skoda. Obviously many of these makes are now 5 stud so this only applies to older cars.
You must ensure it's tight on the hub otherwise the studs are doing double the work. ~May require a spigot ring (looks like a little bangle made of plastic/metal and snaps into back of wheel).
Just found this (not mine, someone else's):
4x100 pcd wheel list
here we go everyone i've been busy..
GUIDE ONLY don't sue if i got some wrong......
new mini et 35 c/bore 57.0
bmw 3 (e30) et 15..25 c/bore 57.0
DAEWOO
espero,neubira,lanus,nexia et 38..42 c/bore 56.6
DAIHAUTSU
applause,charade,grand move et 38 c/bore 56.0
sirion et30..38 c/bore 54
HONDA
civic,crx,concerto,prelude>91
accord>91 et35..38 c/bore 56.0
KIA
sephia,mentor,concord,shuma et 35..38 c/bore 56.0
MAZDA
121>95,323,demio,mx3,mx5 et 35..42 c/bore 54
MITSUBISHI
carisma,colt92>,lancer 92> et 35..42 c/bore 56.0
NISSIAN
100nx,almera,micra,sunny et 35..42 c/bore 59.0
PROTON
all models et 35..42 c/bore 56.0
RENAULT
clio,megane,laguna,r19,r21,espace et 35..38 c/bore 60
ROVER
200,400,25,45 et35..38 c/bore 56.0
SEAT
arosa,cordoba,ibiza,inca,toledo et35..38 c/bore 57.0
SKODA
felicia,favorit,pick-up et35..38 c/bore 57.0
SUBARU
justy>95,vivio et35..38 c/bore 59.0
SUZUKI
baleno et 35..38 c/bore 54.0
TOYOTA
corolla,mr2>90,paseo,starlet,yaris et 35..38 c/bore 54.0
VAUXHALL
agila,astra mk3,calibra,cavalier,vectra et 35..42 c/bore 56.5
astra mk2,corsa,nova, et 42..45 c/bore 56.5
VOLKSWAGON
corrado,golf,lupo,jetta,passat>96
polo,vento et32..38 c/bore 57.0
SOME WHEELS MAY NEED MODS TO FIT!!!!
DO NOT!!! TAKE THIS LIST AS 100% BUY AT YOUR OWN RISK!!!!!
B4 ANYONE SAYS .......YES I HAVE TOO MUCH TIME ON THE NET
DAEWOO
DAIHAUTSU
HONDA
KIA
MAZDA
MITSUBISHI
NISSIAN
PROTON
RENAULT
ROVER
SEAT
SKODA
SUBARU
SUZUKI
TOYOTA
VAUXHALL
VOLKSWAGON
