Longer bolts on 5mm spacers?
Moderator: Scirocco Register
goaferboy
Post by goaferboy » Sun Mar 30, 2014 1:51 pm
Simple question really! Do I need longer wheel bolts if I've got 5mm spacers on the rear wheels? They're on at the moment with standard bolts and I got about 5 and a half turns before they became tight.
The wheels still manage to sit on the hub centre bore quite a bit as well if that makes a difference (they're not hubcentric spacers).
bengould
Re: Longer bolts on 5mm spacers?
Post by bengould » Sun Mar 30, 2014 3:30 pm
Technically if you've got 5mm spacers you "should" use 5mm longer bolts. I ran 5mm spacers on my old car with standard bolts and never had any issues though.
Ben.
