Hey all, I'm pretty much about to purchase some ronal turbos, 15 x 7 et 28
Will these go straight on without any problems though, I'm not slammed and don't ever intend on it. I was more worried that they'd foul suspension.
Any advice would be rad.
Max
Ronal turbo
Re: Ronal turbo
actually after some research i've pretty much answered my own question, seems that they go on with no problems..!
81 Mk1 Scirocco Storm
89 Mk2 Golf 5 door VR6
Re: Ronal turbo
They'll physically fit with no problems - the lower ET means they'll be further away from the suspension and closer to the arch. You might get some handling/tramlining issues to varying degrees but it all depends on how you drive and what's acceptable to you. I only keep the RTs on my mk1 for a couple of months - but then I did go through about 20 sets of wheels in two years
Re: Ronal turbo
They sit nice on the rocco. but they seem to be a rather soft material, and do dent quite easily. if you're showing the car then they'll be fine, but if you plan to drive it quite hard you may want to look elsewhere, specially if buying new. just a thought :)
Wassell
Wassell
Re: Ronal turbo
It has been lowered since, not a silly amount, just enough to put about an inch or so between the wheels and the arches... If that makes sense...
Hope you like!
Hope you like!
- porkymcchop
Re: Ronal turbo
Like that alot. The ronals look awesome on the roccos
Daily: Toyota Hilux Proper Work Yoke
Weekend: VW Touareg R-Line
Project: 88' Rocco Scala
MCFC
MCFC
