Vauxhall brake upgrade - how old?
Moderator: Scirocco Register
kidcrewbob
Post by kidcrewbob » Mon Aug 30, 2021 11:41 am
Read all the threads re using Vauxhall Tigra/ Corsa / Astra VX calipers and 256mm sonversion but not clear how far back you need to go - seems plenty 2006 on but none much older AFAIK - are they still compatible in this date range - VXR Corsa D calipers seem plentiful but are they still good for the job.
TIA
big_wig_074
Re: Vauxhall brake upgrade - how old?
Post by big_wig_074 » Mon Nov 15, 2021 9:51 pm
Older than that I think, but if you want a 256mm set up I have a pair of 16v GTi calipers and Scirocco 16 carriers sitting around that will bolt on once cleaned up for less than the cost of the carrier's. I've upgraded to 295mm 2 piece discs.
kidcrewbob
Post by kidcrewbob » Tue Nov 16, 2021 8:42 pm
Thanks mate sound perfect - what are you looking for them and whereabouts are you as could pick up if not too far I'm in the Midlands halfway between Brum & Manchester
big_wig_074
Post by big_wig_074 » Wed Dec 01, 2021 12:13 pm
seems i dont get on here often enough sorry. im in swansea. i can arrange postage no real bother though
big_wig_074
Post by big_wig_074 » Wed Dec 01, 2021 12:14 pm
send me a pm if youre interested as i might get an email notifying me then. :-)
big_wig_074
Post by big_wig_074 » Wed Dec 01, 2021 12:17 pm
just checked my emails, carriers cost me £59, so ill do them with calipers at £50 plus postage?the calipers will need a strip and clean etc...
