WINSTON 1988 GT MK2
Moderator: Scirocco Register
RussGLAuto
Re: WINSTON 1988 GT MK2
Post by RussGLAuto » Mon Jun 08, 2020 7:14 am
We need to get you on TV... Never mind Goblin Works Garage, how about Winston Works Garage!!
This level of fabrication is nothing short of genius.
While I'm a stock sort of bloke I can't wait to see how this turns out. Keep it up!
essextom
Post by essextom » Mon Jun 08, 2020 1:13 pm
loving this build, cant wait to see it finished
treefingers
Post by treefingers » Fri Jun 26, 2020 8:59 pm
cheers dude, i'm looking forward to that too
treefingers
Post by treefingers » Fri Jun 26, 2020 9:58 pm
Time for a wee update now it's cooled down a little bit, what a scorcher of a week!
Time to talk about power steering.. I really wanted to do it for this build, to do something different and new from before. Will make it much easier for parking and I'm hoping it will make it easy to handle the power, and my logic is that FWD 350hp+ BTCC cars have hydraulic power steering..
I am really surprised that there isn't a more simple how-to guide for power steering for this chassis. I did discover two working options though, the Bluebird rack or the Starlet rack, but both are old and hard to get hold of. I didn't want electric power steering, so no Corsa column would do for me. In my new technique of searching somewhat randomly on ebay, I found out the Nissan Micra K11 rack looked good. It was mounted in the same way as the Rocco rack and had the hoses on the top/front. I ordered one from ebay and set about trying to see if I could make it work.
The Micra brackets needed the holes welding up and redrilling to the Rocco bulkhead m8 studs
Rack in the Roc, some work to do but it is a real possibility now
Some spacing needed!!!
The Micra track rods are m14x1.5 inner and m12x1.75 outer. The Scirocco outer track rod ends are m14x1.5, so my task was to find a track rod with m14 threads both sides to use Rocco rod ends. Some ebaying revealed Fiesta MK7 1.0 track rods are the correct thread, and 290mm long. Was about to get these until I found out Polo 6n rods are m14 both ends, and 310mm long! The extra length was needed so I got a set.
Micra rod on left, 6n rod on right
The 6n thread was longer so I made it the same as the Micra thread. What is nice about the 6n rods is you can tighten with a spanner, the tool for tightening the Micra rods is a set of stilsons !!!!
The Rocco and Micra racks compared. There ended up being 2mm difference in length between the two, I had slightly shortened my original rack so this setup would be even shorter than a standard rocco rack but it's perfect for my needs.
My rack is shortened for flipped rod ends.
Much searching yielded some poly bushes that are correct for the rack, and they come from a Nissan Pulsar and are made in Australia! I very nearly got Nissan Figaro bushes but luckily they are too small and I feel that Nissan Figaro is maybe a step too far!!
'OPERATION: GET ENGINE BAY SEALED IN EPOXY PRIMER SO IT DOESN'T RUST BEFORE I FINISH THIS DARN THING'
As above.
I ground the welds on the bulkhead, tricky and time consuming to do this without eating away the already thin material
I fixed the second bit of rust that was needed to be cut out. This car is solid, and that is pretty darn groovy. I welded this patch on the inside.
Got the duct for the heater blower all welded up, I had to weld it in 4 different pieces in order to get enough epoxy primer in all the chassis leg. Took ages but done properly now. I sprayed a lot of epoxy in the chassis leg !
I stripped the bay back to bare metal and prepped it up. A lot of tools were used:
2 different wire wheels on drill, 75 and 80mm
115mm twist knot wire wheel on grinder, great when it fires bits of wire in your face!
10mmx330mm belt sander
25mm rotary sander on die grinder
150mm DA sander
50mm DA sander
Bare metal is nice!
Welded a spreader plate behind the turret bars, and another on the other side of the turret, incase I decide to put a roll cage in with bars going through the bulkhead
No need to go mad with stitch welding, I'm not making a rally car.. Some extra welding on the rack mounts was a good addition though
Finally got it in epoxy as the sun was setting, a long day to get to this stage but very pleased to get it done :yahoo:
It's *ahem* well covered
Went over the inner wings and interior side of bulkhead too.
treefingers
Post by treefingers » Sun Jun 28, 2020 8:04 am
New challenge:
HOW TO JOIN MICRA RACK TO STEERING COLUMN?
How do I do this hmmmm
Hmm hmm hmmmm
Whilst cycling home one day and pondering this question, I began thinking that I welded up the bulkhead mounting holes for the Rocco column, and the bearings are rubbish and expensive, and it would need chopping up and it doesn't fit my new PS rack UJ. Logic decided that I throw the Rocco column in the bin and find a better unit.
The simplest thing was to find a column that fits right to the Micra rack. Not wanting too many Micra parts on my car, I decided that Nissan Almera looked good, was height adjustable and was £22 on ebay (!). Cheap and better bearings than the VW unit: ball bearings at the top and needle bearings at the bottom.
The bottom joint just needed lengthening but and there wasn't enough shaft there for the required lengthening and the safety joint had loads of rubber in it. I decided to sacrifice the whole column for the splined bit at the bottom and find a new column to join to the splined bit. I want to retain all the collapsable safety features of any column I use. Being impaled in a spikey shaft is not in my future plans..
Joint removed
Some fire added
Turned down
Ready to be welded to a yet-decided-column
I cut a hole in my heater duct so I could spray epoxy primer into the chassis leg, it will be welded back on !
Yesterday I finally got the rack sitting where it needs to be. Mounting the Micra rack flush against the bulkhead mounts made it foul slightly, so I first tried spacing the top out by 8mm with some bracketry modification and these fabricated wedge thingys
This spacing was too much, as the UJ sat too far out. The angle was too great, so I reduced the wedgy spacer to 4mm at the top, and it is now perfectamundoo :pilot:
The brackets were modified accordingly
It looks subtle but makes all the difference
whiteshark
Post by whiteshark » Tue Jun 30, 2020 11:45 am
One of, if not the most awesome builds to ever grace this forum. What engineering skills, ingenuity and pushing the boat out.
Love the fact that your after a working car and not a show car, however, this is one to show off !
Why, man, he doth bestride the narrow world Like a Colossus, and we petty men Walk under his huge legs and peep about To find ourselves dishonorable graves. Men at some time are masters of their fates. The fault, dear Brutus, is not in our stars But in ourselves, that we are underlings.
Would love to see this in the flesh and have a peep about when its finished! Truly a masterful build. Good luck! I even think some of the guys at the Karmen factory would have their hat off to you!
C 20 CCO
Post by C 20 CCO » Tue Jun 30, 2020 7:07 pm
I have to agree with whiteshark, simply stunning matey. When finished, I would love to see your recreation in the flesh.... if it would stand still long enough!
kind regards,
Dave.
To be old and wise......
In the garage : 2005 Volvo V50 2L D in brilliant blue metallic.
2011 Mazda2 Tamura in vibrant ebony metallic.
Prized possession- 1991 GT11 in Pearl green metallic.
Post by mark1gls » Tue Jun 30, 2020 10:33 pm
Love this thread, so many great ideas and brilliant fabrication, keep the pictures and updates coming :-D
treefingers
Post by treefingers » Sat Jul 25, 2020 8:38 am
thanks all :)
this week i decided to break my fingers at work, so i'm out of action for a while. so a slowly typed update..
air con is happening. I want to boost around in this thing in the blistering heat of summer and have ice cold dry air blasting out the vents. I've had to do a bit of reading about how aircon actually works, which I really enjoyed. Hopefully I can make it happen, with a bit of determination
Here's my plan, to use most of the system from my Audi TT MK1 parts car:
Compressor (will bolt straight to my 20v, and the bracket will let me use the 20v power steering pump too :) )
Condenser and drier
Pipework (some of it)
Pressure switch (F129 from earlier cars, not the G65 pressure sensor)
Expansion valve
Evaporator
To control the air con I plan to have a switch on the dash that energises the clutch on the compressor, and the a/c will only kick in when the pressure switch allows it to. There is an ambient temperature switch that I could run too (wont let you turn the a/c on if it is 0 deg C outside) but don't know if I will bother with it.
I have been reading the TT service manual and the expansion valve is thermo controlled, meaning it will change the refrigerant flow entering the evaporator based on the temperature of refrigerant leaving the evaporator.
I'll need to run two fans too to get adequate cooling, I'm thinking of using the fan control module from either the TT or a MK3 Golf so I can have dual speed fans but I need to look into if this is feasible!
Essentially I need to make some kind of arrangement of this:
Fan blowing through evaporator > blowing through heater matrix > going to various vents in the cabin > me being like 8-) 8-) 8-) 8-) 8-)
The evaporator will have water dripping off it so the fan can't be underneath though. I've now cut out the fabricated cabin duct and will be mounting the fan in it's place. Some design needed for the heater box, but I'll make it from thin stainless. The heater box is going to eat into the passenger footwell a little, but I'm OK with that if it's not too much. It makes sense to me now why modern cars have such deep dashboards, the HVAC system under there is massive.
Here's the TT condenser just sitting in location. This particular one is just for mocking up. It's only 20mm wide but is about 400mm high, not a standard Rocco fit. Luckily I have hacked the sh-t out of Winston.
Tweaking of position, and an oil cooler squeezed in for good measure! The oil cooler is Mocal 19 row, 235mm wide. Trackday happy :)
I've started the mounting of the cooling packs. A 22x3mm round bar was flattened by heating to cherry red and squashing in our brake press. This doesn't squash easily!
Took a few tries until I was happy with it
The bar bolts to the bonnet catch towers
A plethora of rubber mounting and bracketry to come.. when I get my hand working properly..
I've sent back my floor mounted pedal box and replaced with a top mounted version as I think it will feel much more natural. I've also ditched the hydraulic handbrake and staying with a normal one! I'm leaning towards being practical vs looking like a race car and leaking fluid all in the cabin :-D
Need to decide how to mount this and find a new steering column that will go between the brake and clutch pedals, but under the cylinders, and also make the ultimate driving position. I need some seats for that!!
Post by GTXTRA » Sat Jul 25, 2020 11:37 pm
Andy - simply stunning.
C 20 CCO
Post by C 20 CCO » Sun Jul 26, 2020 7:29 pm
Look after those hands matey
kind regards,
Dave.
