Drive Shaft
- scrumpyone
Drive Shaft
Got some clunking & creaking noises from the steering. Mechanic diagnosed universal joint. Ordered part from VW, they sent wrong one. It seems I require part number 532419951B Drive Shaft.
Can anyone help please? It's a MK2 GT2
Dave
Register No:1110
'79 MK1 GLS (R.I.P.)
'91 MK2 GT2 (alive & kicking)
Register No:1110
- unknownmale
Re: Drive Shaft
The UJ is not a drive shaft. Drive shafts run from gearboxes to driven wheels or Diffs.
The UJ connects your steering rack to your steering column.
You cannot buy these new anywhere.
But this part will be the same for all RHD A1 chassis cars. Any mk1, mk2 scirocco, mk1 golf, mk1 caddy etc
- GT_II
Re: Drive Shaft
VW Classic parts in Germany have 4 left in stock:
https://www.volkswagen-classic-parts.de ... e&dir=desc
Mecatecnic in France can get them in and charge cheaper postage, if you're not in a hurry:
https://www.mecatechnic.com/en-GB/532-4 ... 096721.htm
- scrumpyone
Re: Drive Shaft
Ordered one from Heritage Parts Centre for £127.
There was a used option on fleabay for £80 but I decided not to risk it.
Dave
Register No:1110
Register No:1110
Re: Drive Shaft
The UJ is so expensive for such a small bit of metal...
Re: Drive Shaft
if its that expensive then why not buy the whole shaft and be done with it?
https://www.eurocarparts.com/driveshaft
Re: Drive Shaft
i dont think theyre that expensive?
https://www.eurocarparts.com/cv-joint-kits
- GT_II
Re: Drive Shaft
It's not a drive shaft scrumpyone was looking for - that's just VW's sloppy translation! He was looking for what I think you would call the steering column flexible coupling rod.
Re: Drive Shaft
ahhhhhhh
did wonder where we were going with this
- unknownmale
Re: Drive Shaft
Left hand drive though unfortunatelyGT_II wrote: ↑Thu Jul 25, 2019 10:06 am VW Classic parts in Germany have 4 left in stock:
- GT_II
Re: Drive Shaft
Well, VW Classic Parts had 4 RHD ones on 25 July, now they have sold out. So the links have expired. You have to act quickly on some of these rare parts! I wonder if they are on their way to Heritage Parts Centre (currently showing out of stock)?
- scrumpyone
Re: Drive Shaft
One's on it's way to me.
Dave
Register No:1110
Register No:1110
Re: Drive Shaft
When you don’t need one this one appears on eBay....
https://www.ebay.co.uk/itm/Volkswagen-S ... SwA~ddUDJo
- scrumpyone
