Rear driver side leak
Moderator: Scirocco Register
NebToast
Post by NebToast » Sat Apr 27, 2019 10:38 am
I'm having real trouble fixing a leak on my gt2. The water pools below the rear driver side taillights just under the rear washer bottle.
I've been keeping a sponge there for when it rains, but I've done nearly every seal now and it's still leaky.
I've used bitumen sealing tape on the rear lights and the screws. I've put new seals on the gas strut mounting points. I've used silicone on the badges and replaced the lock seal but it's still pouring in! Only one side however which is most peculiar.
Any ideas?
blakey
Re: Rear driver side leak
Post by blakey » Sat Apr 27, 2019 1:43 pm
Rear spoiler mounting points
Sent from my Moto Z2 Play using Tapatalk
'89 Sapphire Scala Inj.
Member No. 1455
Blueshark
Post by Blueshark » Mon Apr 29, 2019 8:44 pm
Rear window seal, sealant has dried out after all these years and now lets water through between the glass and seal.
When you open your rear lid does water come out of the holes in the underside ?.
1 = window
2 = seal
3 = chassis
4 = sealant.
NebToast
Post by NebToast » Thu May 02, 2019 10:05 am
Rear spoiler mounting points Image
Seems like you were bang on. I put some bitumen sealant around the brackets and that seems to have stopped the leak.
