SOLD 1985 GTL - £2500 - Crystal Palace REVISED 12th January 2020
IT'S NOT DIFFICULT - follow the simple template, include as much info as possible. NO TRADERS. NO PRICE? thread will be deleted without checking. Using English and Paragraphs always a winner too.
Moderator: Scirocco Register
Post by GTXTRA » Sat Jan 19, 2019 6:06 pm
Model: MK2 GTL
Year: 1985
Mileage: 120,924 - I've done about 25K miles since car went on road in 2008
MOT: yes - 7/9/2020
Current owner: yes
V5 present: yes
Price: £2,500
Contact Details: via here or email brmgtx87-forums@yahoo.co.uk or on FB if you know me.
8-)
Full project thread - http://forum.sciroccoregister.co.uk/vie ... p?f=19&t=4
I've owned and loved Project Rouge since rescuing it August 2008. It get's a LOT of attention on the road.
General - 1985 GTL, Titian Red with beige velour interior, brown dashboard and door cards. 1781cc EX Engine, 4 + E gearbox - sits at 3k revs at motorway speeds.
Maintained regardless of expense by The Phirm since recommissioning in 2008. Full folder of invoices to go with car.
Recent new filler neck, fuel tank and exhaust plus this month a new VW Cambelt, new crankshaft oil seal, new rear cylinders, front brakes stripped and cleaned up month.
New top mounts plus a full checkover of hubs, bearings Jan 2019.
Features/upgrades - AP Coilovers, Adjustable lower front stress bar, factory spec boot arch liners as per GTX/Storm
Weighted Gear shift, Weber carb/manual choke, Headlamp loom upgrade with relays, Sony Bluetooth Stereo and Pioneer Speakers all working fine
Good points
A reliable, well maintained car mechanically - see list of jobs carried out since I've owned it.
Good interior - some slight fading on top surface of drivers seat back plus tiny cracks around dashboard air vents, replaced the original carpet with a set from a Storm, Original Justmatz floor mats.
Less good
This is not a showcar - I refer to is as my Tesco car in fact.
Slightly scabby around the edges - but nothing that a gentle restoration wouldn't resolve, nothing hidden given no bodykit.
Front valance out of shape - NOS one can be supplied if car sells at a certain price
Small dents on rear panel around number plate recess/under light cluster
A few minor blemishes/dings
Pattern offside front wing
Glass sunroof - fully functioning tilt/removeable, requires yearly dose of http://www.captaintolley.com/ around the hinge bolts, that's all. Slight, non leaky airsqueal at motorway speed
Items/components changed or serviced
Item Miles Date
alternator voltage regulator 116756 20-May-2016
battery 116714 1-May-2016
bottom hose 115000 23-May-2015
brake discs 99766 24-Apr-2010
brake fluid 119127 25-Nov-2017
brake hoses 96870 24-Feb-2009
brake pads 99766 24-Apr-2010 front brakes stripped and caliper sliders repaired Jan 2020
brake shoes 106529 21-Dec-2015 cleaned 6 April 2019
brake cylinders 120857 11-Jan-2020
cambelt and tensioner 120857 11-Jan-2020
carburettor 113990 14-Mar-2015 service kit,new FEBI Bilstein Gasket
clutch release bearing 120,638 6-Sep-2019
coolant 119127 25-Nov-2017 g13
coolant reservoir 113085 5-Aug-2014
crankshaft oil seal 120857 11-Jan-2020
cv gaitors 96321 1-Sep-2008
cv joints - outer, both 119391 7-Feb-2018
diveshaft flange seal - ns 119391 7-Feb-2018
dizzy cap and rotor 119127 25-Nov-2017 cleaned 25 November 2017
exhaust centre section 116250 12-Mar-2016 old one to be repaired
Exhaust down pipe 108885 17-Aug-2013 repaired down pipe fitted 8/13
Exhaust rear box 119391 7-Feb-2018
filler neck 117189 24-Aug-2016 new filler neck
front bearings checked 6 April 2019
fuel filter 119127 25-Nov-2017
fuel pump 113880 8-Feb-2015
fuel tank 117189 24-Aug-2016 new tank
fuel vapour separator 113872 20-Dec-2014
gear linkage rod arms 119391 7-Feb-2018
gearbox oil 119127 25-Nov-2017
k and n air filter 98423 1-Sep-2009 cleaned 25 November 2017
ns steering rack gaitor 96870 24-Feb-2009
ns track rod 108886 17-Aug-2013
oil cap 116175 30-Jan-2016
oil change 119127 25-Nov-2017
oil filter 119127 25-Nov-2017
oil pressure switch 119391 8-Feb-2018
os track rod boot 119391 8-Feb-2018
plug leads 118003 18-Aug-2017
radiator 96000 17-Jan-2009
rear bearings 116036 21-Dec-2015 checked/cleaned 6 April 2019
rear bushes checked 21 December 2015
rocker gasket 119744 9-Jun-2018
spark plugs 119127 25-Nov-2017 NGK BUR6ET
speedo cable 117189 24-Aug-2016
speedo gearbox seal 109059 21-Sep-2013
steering rack 112041 26-Apr-2014
sump gasket 116175 30-Jan-2016
suspension 96870 24-Feb-2009
top mounts 120491 6-Apr-2019
v belt 120857 11-Jan-2020
water pump 104525 6-Jul-2012
Wipers front and rear 119744 21-Apr-2018
If I get £2,500 or near I will be happy to leave the VERY nice Nardi Votex steering wheel in the car - Otherwise I will add a factory VW steering wheel.
Car will be supplied with G60 style steels - I am retaining the super rare 6.5 x 15 Castellets currently fitted to car - that come with legal tyres.
Brand new orange front indicators will be fitted to car prior to any sale.
So - there you are.
A totally useable example of one of the very rarest non bodykit Mk2 Sciroccos - less than 10 left I believe? - that would make for a perfect retro runabout or is a great basis for a fuller restoration.
Re: 1985 GTL - £2500 ONO - Crystal Palace - gauging interest
Post by GTXTRA » Sat Jan 19, 2019 6:12 pm
Re: 1985 GTL - £2500 - Crystal Palace
Post by GTXTRA » Sat Sep 14, 2019 10:56 pm
New photos taken 14th September.
Post by GTXTRA » Sat Sep 14, 2019 11:31 pm
Re: 1985 GTL - £2500 - Crystal Palace REVISED 12th January 2020
Post by GTXTRA » Sun Jan 12, 2020 8:50 pm
Pictures 12 January showing car on the G60’s.
Jim H
Post by Jim H » Tue Jan 14, 2020 12:39 am
Hi, I'm very interested as I've had a gtl before and don't really like the bodykits. Bearing in mind I'll have to come up by train.... When would I be able to have a look at it, please?
Post by GTXTRA » Tue Jan 14, 2020 8:42 am
This Sunday would be fine Jim.
Drop me an email as above or pm me.
Jim H
Post by Jim H » Wed Jan 15, 2020 7:13 pm
Hi,
I am sorry, I won't be coming up on Sunday as I bought the one I looked at today.
Thank you, Jim.
Post by GTXTRA » Wed Mar 11, 2020 12:14 am
She got to go, Mr Funk wants to stick with a Golf and others have failed to follow through with interest.
jonGTX
Post by jonGTX » Fri Mar 13, 2020 8:53 am
Times when you wish you weren't paying out on a PCP new car.....
Rocco Mafia Car of Choice 2010
1989 Helios Blue Scala 16v *sold*
1994 Mulberry Corrado VR6 *sold*
1991 Tornado Red Scala GTi Engineering RE2000 8V *sold*
1991 VW Polo G40 *sold*
1990 Pearl Green Scala
2020 VW Polo GTi
