Hi,
I've been looking at putting 15x8 et25 on the rear of my Mk2 with 195/45 tyres, can someone confirm these will fit without arch mods and without scrubbing most importantly!!! I was going to go 7x15 et25 but it won't give the look i'm after.
Any help much appreciated.
15x8 Help/ advice please
- unknownmale
Re: 15x8 Help/ advice please
I have 15" 7j et25 on the rear with 195/45/15 on and i've just ordered a 10mm spacer as they're just a bit too tucked in. So I think you'll be fine on the arch and should have enough space to the spring.
Looking at the banded steels i noticed this
15x7 et25 15x8 et 20 15x9 et15
Those sizes definitely seem about right then, thanks a a lot for the info, I'll post pictures when it's done :)BlackGTX wrote:Looking at the banded steels i noticed this
If you're local to Surrey, I've got 15x8 ET0 with 195/45 that you could try. If that fits then ET25 will be no problem
