87 Black GTX
Moderator: Scirocco Register
scrappy1382
Re: 87 Black GTX
Post by scrappy1382 » Sun Apr 30, 2017 4:59 pm
looking good pal. funnily enough the 20vt has the golf 1.3 cable too. didnt realise untill i checked the paperwork that came with the car.
ideas on time/date wise on getting her running ? nationals is quickly creeping up !!!
Scirocco Shane
84 Havanna Brown Storm - 8-)
BlackGTX
Re: 87 Black GTX
Post by BlackGTX » Sun Apr 30, 2017 5:45 pm
hoping that a few more full days on it and itll be ready to start, then its a case of setting it up and testing
got a feeling im going to need a different starter and possibly alt to connect to the loom
Resto Rocco
Re: 87 Black GTX
Post by Resto Rocco » Sun Apr 30, 2017 9:20 pm
Good on ya. Really nice find! I'm in to see where this goes. Im also looking at either a 20vt or letting my aggression out with an RB25Det
scrappy1382
Re: 87 Black GTX
Post by scrappy1382 » Mon May 01, 2017 4:54 pm
Popped over to see blackgtx today, gave a helping hand with a top mount and exhaust system Image
Sent from my Moto G Play using Tapatalk
Scirocco Shane
BlackGTX
Re: 87 Black GTX
Post by BlackGTX » Mon May 01, 2017 4:56 pm
bit more progress with thanks to scrappy who swung round and helped out
did one top mount and we jacked the back up and got the rest of the exhasut fitted
BlackGTX
Re: 87 Black GTX
Post by BlackGTX » Sun May 07, 2017 3:16 pm
still chipping away at this, got some clearance issues at the mo
it all looks ok
dizzy fouls, should be able to rotate it but there are only 2 positions to bolt it in
had to use a flat brake res cap as the induction arm sits on it and the coolent hose wants to go through it at the mo
BlackGTX
Re: 87 Black GTX
Post by BlackGTX » Sun May 07, 2017 3:28 pm
been a complex build so far using a combo of parts
abf engine
abf 45° dizzy
dx fly, cluch and gearbox
16v inlet and supports
16v induction arm
abf throttle body, 16v cable holder
golf 1.3 throttle cable
dx airbox
abf isv
16v injectors and lines
16v loom ecu and knock box
16v knock sensor
16v lambda sensor
scirocco abf 421 manifold and exhaust
polo g40 master cylinder vacuum pipe
polo cl oil breather hose
all this because i wanted the engine to look natural in the bay and not hacked in. no idea on what sort of power it will produce
scrappy1382
Re: 87 Black GTX
Post by scrappy1382 » Sun May 07, 2017 10:10 pm
looking good buddy. like everything, it all takes time and patience. your doing a good job. keep going with this.
Scirocco Shane
BlackGTX
Re: 87 Black GTX
Post by BlackGTX » Mon May 08, 2017 6:37 am
itll get there, be worth the effort too
BlackGTX
Re: 87 Black GTX
Post by BlackGTX » Wed May 31, 2017 4:20 pm
fitted this also, really tight fit. atleast vw had the sense to make it from a flexible plastic
BlackGTX
Re: 87 Black GTX
Post by BlackGTX » Wed Jul 05, 2017 5:38 pm
Laid this on to see how it fits, need to flatten the bottom line
BlackGTX
Re: 87 Black GTX
Post by BlackGTX » Sun Jul 09, 2017 11:07 am
Petrol tank out, discovered when doing the exhaust that the tank leaks from the lip. New ones not in yet, need to foam the top and will probanly paint the heat shield now i have time. No nationals this year
BlackGTX
Re: 87 Black GTX
Post by BlackGTX » Mon Jul 24, 2017 6:20 pm
This was from a few weeks back, pulled it out to clear the garage or scrap
Not got the mew tank in yet, that'll have to wait a while. Need to swap the suspension over too then adjust camber and tracking
steve bain
Re: 87 Black GTX
Post by steve bain » Wed Aug 02, 2017 9:19 pm
I do like your wheels.....
My build thread:
viewtopic.php?f=19&t=14083
BlackGTX
Re: 87 Black GTX
Post by BlackGTX » Thu Aug 03, 2017 6:12 am
steve bain wrote:I do like your wheels.....
Can buy them here
http://www.bulletwheels.co.uk
Mine are 8j 185 50 15 and 9j 195 50 15. Ill be getting new ones when its running
