GTI Hella Lights
Don't know German? look here
Moderator: Scirocco Register
whiteshark
GTI Hella Lights
Post by whiteshark » Tue Jun 26, 2012 1:53 am
Whats the Hella lens / part number for the GTI / USA style lights. Can any of the US sealed beam units be used in the UK or better to replace them all?
Re: GTI Hella Lights
Post by ianaudia4 » Tue Jun 26, 2012 11:02 am
The US ones will fail an MOT as the beam is the wrong way, to keep it legal UK ones have to be ftted.
Post by the edmundator » Wed Jun 27, 2012 11:21 am
MRMENDER is something of a self-confessed HELLA 82-GTI style headlight spotter and I'm sure he will be able to help. Unfortunately my GTI is not nearby so I can't read off the part number for you.
They are a common part to many vehicles (including early Audi Quattros, early 80s Renaults and lots of commercial vehicles) and you can still get the lights from Hella stockists. They have different frames and trims to normal Scirocco lights which need to be purchased separately - I think they're still available from VW Classic Parts.
DT1
Post by DT1 » Wed Jun 27, 2012 12:04 pm
whiteshark
Post by whiteshark » Wed Jun 27, 2012 11:40 pm
Have frames, lenses only required.
