tensioner idler pulley bolt woes.
Moderator: Scirocco Register
C 20 CCO
Post by C 20 CCO » Wed Apr 08, 2020 4:41 pm
Hi all, hope you’re in good shape at this time.
I’m having a problem trying to get the double ended bolt to thread cleanly into the engine casting. The thread looks damaged so I’ve been trying to repair it, even sawing off the first two two threads. And it still won’t play ball. The other end of the thread that holds the tensioner is fine it’s just the thread to the engine. So since it’s now toast, do I source another new one or do I re-use the old one! What would you do? Remember the vw dealers seem to be closed at the moment.
I bought the continental brand of timing belt kit if that makes a difference.
Cheers in advance.
kind regards,
Dave.
To be old and wise......
In the garage : 2005 Volvo V50 2L D in brilliant blue metallic.
2011 Mazda2 Tamura in vibrant ebony metallic.
Prized possession- 1991 GT11 in Pearl green metallic.
unknownmale
Re: tensioner idler pulley bolt woes.
Post by unknownmale » Wed Apr 08, 2020 4:55 pm
The stud you need is - n90296401
Comes with some timing belt kits. Run a thread chaser into the hole first, blow it out with air then use the double nut method or a stud installer to put it in.
C 20 CCO
Post by C 20 CCO » Wed Apr 08, 2020 4:58 pm
Brilliant cheers matey, I used the double nut method to release the old stud. Didn’t know I could use the same method to reinstall. Will look around for a new stud... thanks again
kind regards,
Dave.
C 20 CCO
Post by C 20 CCO » Sat Apr 18, 2020 1:23 pm
I reused the stud I had because the new stud was U/S. I tried to repair the threads on the new stud but it couldn’t be saved so binned it. With the lockdown local vets dealership is closed.
New timing belt, tensioner, washer and nut fitted. Had to use strobe light to retune dizzy, and all seems to be ok.
kind regards,
Dave.
