Over-run
SCOTMCDOT
Over-run
Post by SCOTMCDOT »
Where i have started driving my Rocco again recently i have noticed that i am sometimes getting a small amount of over-run when i switch off the engine.
What causes this?
wasted
Re: Over-run
Post by wasted »
A number of things can cause this - but commonly caused by leaky injectors.
SCOTMCDOT
Re: Over-run
Post by SCOTMCDOT »
Mines a carb, possibly a carb problem?
richlyons
Re: Over-run
Post by richlyons »
mine does the same thing, get rid of the carb and go for a webber :hugegrin:
could be the dizzy timing? not sure on that though, it only what i got told.
1988 helios blue scala, weber carb, gti cam,
1989 red gt2 (daily)
wasted
Re: Over-run
Post by wasted »
Not sure on the dizzy timing... Don't see how that could cause overrun really, it should be a fuelling issue. If yours is a carb, I couldn't give you a decent answer I'm afraid... Perhaps an over-rich mixture?
richlyons
Re: Over-run
Post by richlyons »
i didnt see what the dizzy would do either :dunno:
but a guy from vw told me, he also order the wrong part 2 times :(
KindredSpirit
Re: Over-run
Post by KindredSpirit »
Can be caused by incorrect timing, or a build up of carbon on the tops of the pistons, requiring a 'decoke'. this causes the hot carbon on the pistons to carry on firing the fuel, but that doesn't happen very often these days with improved fuel.
Sorry - showing my age. :cry:
John
SCOTMCDOT
Re: Over-run
Post by SCOTMCDOT »
Will get it tuned then. Have noticed it pinking a bit in the last few days too :roll: so its pointing in that direction.
