coolant temperature sender, on thermostat housing
Best place for the above for a 1990 Scala DX injection?
Re: coolant temperature sender, on thermostat housing
I'm confused - there isn't a temp sender on the thermostat housing.
If it's the small one - with the slide on spade connector then it's 049919501 (check on the sender though as it might have a B on the end). Fairly cheap from everywhere - Heritage, B&B on ebay or classic-vw
https://www.classic-vw.co.uk/water-temp ... 5214-p.asp
