Fan belt
Moderator: Scirocco Register
Village Idiots
Fan belt
Post by Village Idiots » Wed Mar 28, 2018 5:04 pm
I believe the correct width for fan (alternator) belts is 11.9mm
The only ones available which I can find are 10mm, does anyone know if wider ones are available and, if so, where from?
Re: Fan belt
Post by mark1gls » Wed Mar 28, 2018 9:44 pm
10 x 950 is the size I use in both my cars.
https://www.ebay.co.uk/itm/VW-GOLF-MK1- ... XQjUNR1XvP
List in signature.
Village Idiots
Re: Fan belt
Post by Village Idiots » Thu Mar 29, 2018 8:21 am
Mark,
Do you have the alternators with pressed steel pulley?
I have been told that the 10mm belt goes right down to the bottom of these rather than the more effective way of gripping the pulley on the sides, resulting in a greater tendency to slip slightly. If I go through standing water, not particularly deep, the charge warning light comes on for 30 seconds or so, suggesting just such slippage.
Jem
blakey
Re: Fan belt
Post by blakey » Thu Mar 29, 2018 3:05 pm
The parts catalogues specify a 9,5X950mm belt for non air con & non power steering models. It could be that your pulley is worn if the belt still slips when tensioned correctly.
'89 Sapphire Scala Inj.
Member No. 1455
Eagle1
Re: Fan belt
Post by Eagle1 » Thu Mar 29, 2018 5:13 pm
It should be a V belt and not a toothed one. A toothed belt with "wind" itself into the pulleys causing it to burn and squeal. If you're changing it it's a good idea to clean the pulleys off before fitting the new belt. Have a look on here for the part numbers applicable to your car.
http://www.realoem.me/Volkswagen/RDW/SCI/1986/13/R/9
