Accelerator pedal rubber grommet - Part No
Moderator: Scirocco Register
Mark H
Post by Mark H » Sat Dec 30, 2017 1:22 pm
All
Looking for the part number for the rubber grommet that holds the throttle cable in at the top of the accelerator pedal.
Thanks in advance
Mark
Mark
Alpine White
VW Scirocco GT2 (1991)
Membership Number 1296
Re: Accelerator pedal rubber grommet - Part No
Post by mr.brown » Sat Dec 30, 2017 3:06 pm
431 721 559
You can find it yourself at http://www.oemepc.com :good:
blakey
Post by blakey » Sat Dec 30, 2017 3:41 pm
'89 Sapphire Scala Inj.
Member No. 1455
Post by mark1gls » Sat Dec 30, 2017 7:27 pm
Best getting a Mk2 golf grommet, it’s made of harder rubber compared to the foam type VW fitted. GSF sell them for something like 65p.
Grommet needs a little grease to help it slip in and fitted them to both my cars. Check the adjustment on the travel of the accelerator as there should be some slack in the cable.
Post by mark1gls » Sat Dec 30, 2017 7:41 pm
Just had. Look on line and I don’t think gsf are selling the rubber ones any more?
VW heritage
https://www.vwheritage.com/191721559-bu ... golf-84-91
The bush on ebay may also be rubber but can’t tell from the pic?
Try dealer, a couple of years ago they were less than a quid
Vw part number 191721559
