Rocker Cover screws
Moderator: Scirocco Register
Lukeh17
Rocker Cover screws
Post by Lukeh17 » Tue Dec 05, 2017 1:12 pm
Hi
I've just ordered a new rocker cover gasket and the nuts (23) in the picture. Where can I buy the screws (17) ?
https://v2uploads.zopim.io/3/Q/Z/3QZ5gZ ... 5ea59b.jpg
Re: Rocker Cover screws
Post by mark1gls » Tue Dec 05, 2017 1:20 pm
Might be worth upgrading to a rubber gasket as less prone to leaking and you can reuse it if you remove the rocker cover again, they come with the studs, you don't use or need the 4 longer silver studs as the kit comes from a Mk3 golf but is a common upgrade from the cork gasket originally fitted.
http://www.ebay.co.uk/itm/VW-GOLF-MK1-M ... XQlgtSpxNg
If you wish to keep the cork gasket you need to get the studs with a shoulder on so you don't squash the gasket, any one that has changed from a cork gasket to a rubber gasket may have 8 spare studs for you or you may need to try calling a VW dealer?
Do you still have the metal bar (21) as that is needed?
If you look 1/2 way down this thread you can see the difference in the studs.
https://vwgolfmk1.org.uk/forum/index.ph ... st_1506479
Post by mark1gls » Tue Dec 05, 2017 1:32 pm
Try VW as ebay is £4.46 for 1.... £35.68 for all 8 is just silly money....
https://www.ebay.co.uk/itm/NEW-GENUINE- ... SwQItT4HPw
Lukeh17
Post by Lukeh17 » Tue Dec 05, 2017 3:14 pm
Thanks for the advice and info Mark
Lukeh17
Post by Lukeh17 » Sun Dec 10, 2017 5:25 pm
Do you know where I can get the bar from?
unknownmale
Post by unknownmale » Sun Dec 10, 2017 5:58 pm
Occasionally they come up on eBay;
https://www.ebay.co.uk/itm/VW-Mk1-Mk2-G ... Swo6lWQjL0
https://www.ebay.co.uk/itm/VW-GOLF-MK1- ... SwcUBYLx0h
You'll need two. You can make something that will do the trick, it just helps distribute the clamping force on the rocker cover gasket. These aren't as necessary with the rubber gaskets, but much more likely to spring a leak without them.
Post by james butler » Fri Dec 15, 2017 6:50 pm
i used normal cap head screws about 20mm long.
the mk3 rubber gasket has metal inserts that prevent over squashing the gasket.
GTXGTXGTX
Post by GTXGTXGTX » Sat Dec 16, 2017 8:47 pm
I replaced the studs with cap heads screws as well.
