Radiator Fan.
Moderator: Scirocco Register
G Beats
Radiator Fan.
Post by G Beats » Tue Oct 31, 2017 7:09 pm
I need to buy a new Radiator Fan for Sally as the bush bearings I have gone in brought one from ebay but it was a three pin I need a two pin.Please find pictures of the Radiator plug connection attached to this thread.
Many thank's to all peoples who can help off here it is more then appercited.
G Beats.Been into MK 2 V.W Sciroccos since 98.Now on my fourth MK 2 Scirocco. R.I.P two MK 2 Scala DX Engine's.Sold GT 2.
Re: Radiator Fan.
Post by Nate » Tue Oct 31, 2017 7:52 pm
The 3 pin one is a 2 speed fan. If yours is a 2 pin then you need to look for a single speed fan
G Beats
Re: Radiator Fan.
Post by G Beats » Tue Oct 31, 2017 9:30 pm
Nate wrote:The 3 pin one is a 2 speed fan. If yours is a 2 pin then you need to look for a single speed fan
Yes Nate it is a two pin fan as you can see from the pictures on here.
unknownmale
Re: Radiator Fan.
Post by unknownmale » Wed Nov 01, 2017 11:57 am
I might have one, will check this weekend
G Beats
Re: Radiator Fan.
Post by G Beats » Thu Nov 02, 2017 3:49 pm
unknownmale wrote:I might have one, will check this weekend
OK thank's.
