My 1.6GT has an issue where the revs will stick at around 3k rpm. Sometimes it does it, sometimes it doesn't. Had a look and there's a diaphragm that pushes a flap open on the left hand side of the carb (opposite side to the throttle) and when I press this the revs drop.
Few places have suggested vacuum leak on one of the pipes or an o-ring that needs replacing.
Has anyone got a bit more info on how to rebuild the carb? Or would I be better off spending the time converting to something like a twin webber?
Thanks, Liam.
Pierberg 2e2 carb Vacuum issue
'88 Scirocco 1.6 8v GT
‘94 Golf 2.8 12v VR6
'02 Grand Cherokee Limited 4.0 I6
'07 Golf GTI 2.0T
'07 Golf GTI 2.0T
- unknownmale
Re: Pierberg 2e2 carb Vacuum issue
As you'll find when looking around the forums, not many people know how to work on these so tend to switch to a Weber dmtl 32/34 as they're simpler to work on. Or if you want to stick with it there is a service manual here: http://vwa1.dadoghouse.com/wp-content/u ... uction.pdf
