Engine internal parts
unknownmale
Post by unknownmale »
Just wondered if anyone can recommend a good place for buying a few things;
big end & bottom end bearings, piston rings, oil pump.
GSF sell these, but i'm not sure I trust them.
sabre0699
Re: Engine internal parts
Post by sabre0699 »
Ferraris Piston Serivces Ltd www.fpsdistribution.com , branches all around the country and will keep good quality bearings and rings, re the oil pump try VW you might be suprised
Another option is if you have a local TPS who supply all the parts to VAG group, some will deal with the public others insist trade only ( if so find someone in the trade who has an account )
big_wig_074
Post by big_wig_074 »
vw heritage
