Cylinder heads to fit std 8v carbed gt2 and cams
Moderator: Scirocco Register
scirocco_ne
Post by scirocco_ne » Fri Feb 08, 2019 3:00 pm
Well the old girl is a little smokey now on pullaway but has lovely compression so its most likely stems.
I am looking for a new head to overhaul and fit but im not sure which is exactly the same.
Does the mk1 golf injected head match? Which other match?
Also is there other cams i can use that fit as mine at 145k is a little worn on the lobes.
Thanks as always
Mick
Re: Cylinder heads to fit std 8v carbed gt2 and cams
Post by mark1gls » Fri Feb 08, 2019 7:23 pm
Mk1 Golf and early Mk2 Golf GTi (K-jet) will fit and have a better cam shaft fitted already and they will give you more go, you will need to block up the fuel injector holes on the back of the head. You need to make sure the heads have hydraulic tappets as I guess that’s what you have already, engine after 1984 ish had hydraulic tappets.
essextom
Post by essextom » Fri Feb 08, 2019 9:34 pm
Where are u based? I’ve got a cylinder head you can have very cheap if you can pick it up from Chelmsford Essex.
instagram @dreadnought_customs
82 mk2 gti
88 mk2 scala 20vt
scirocco_ne
Post by scirocco_ne » Sun Feb 10, 2019 12:19 am
Thanks for the info. If i am honest i would like to keep it original and the injection ports are a good point i never considered
scirocco_ne
Post by scirocco_ne » Sun Feb 10, 2019 12:20 am
Is it a carbed head buddy? I am up North but where there's a will....
essextom
Post by essextom » Sun Feb 10, 2019 11:57 am
no mate its a dx head mate.
82 mk2 gti
88 mk2 scala 20vt
scirocco_ne
Post by scirocco_ne » Sun Feb 10, 2019 1:18 pm
Is the injector holes the only difference?
And are the holes easy to blank? Headsets etc identical. If it helps the old girl go little better and i can retain standard looks it may well be. worth it.
Mick
essextom
Post by essextom » Mon Feb 11, 2019 7:36 am
The injector holes can be blanked off using 1p pieces, not sure if the rear heater channel to the inlet manifold is present on the DX heads, ill take a lokk
82 mk2 gti
88 mk2 scala 20vt
big_wig_074
Post by big_wig_074 » Sat Apr 06, 2019 5:15 pm
no heater channel, block the injector holes with 1p coins and chemical metal or something, nice and easy, you wont see them without really looking.
scirocco_ne
Post by scirocco_ne » Mon Jun 10, 2019 8:20 pm
Bit of a thread resurrection :)
What would the impact be on the inlet if the heater channel was missing, carb icing in winter?
Mick
