Top cover was removed to make way for the bottom. I will know more tomorrow and have some pics. They supplied 026109175APeteGLi wrote: ↑Thu Feb 14, 2019 7:52 pm What part number did Heritage supply? 049109175 or 026109175A, because I think you will find that they are exactly the same.
The picture on the oemepc site referred to above, looks nothing like the actual part!
It will fit the top metal cover, but as mark1gls says - you have to remove the top cover in order to fit the bottom cover.
Cambelt cover
Re: Cambelt cover
Re: Cambelt cover
That’s the later lower cover so that’s why it’s not fitting the original metal top cover.
Part 16.
https://volkswagen.7zap.com/en/rdw/golf ... /109-9005/
Type you have for metal top cover.
https://volkswagen.7zap.com/en/rdw/golf ... /109-9000/
Looks like heritage has supplied the wrong part for your car....
I think you want this part, 049109175. I can check the part number on my 1988 car tomorrow.
If you search the part number above.
https://www.ebay.co.uk/itm/Mk1-Golf-GTI ... SwbP1aczIE
Same if I search 1988 Mk2 Scirocco...
https://volkswagen.7zap.com/en/rdw/scir ... /109-9000/
Shows out of stock at VW heritage..
https://www.vwheritage.com/049109175-lo ... v-vw-spare#
Part 16.
Re: Cambelt cover
thanks, I will have a look also at my car and see whats whatmark1gls wrote: ↑Thu Feb 14, 2019 9:44 pm That’s the later lower cover so that’s why it’s not fitting the original metal top cover.
Part 16.
https://www.vwheristage.com/049109175-l ... v-vw-spare#
Re: Cambelt cover
I've had a look and the lower plastic cam belt cover is part No. 049109175.
Re: Cambelt cover
So finally here are some pics of the existing cover.
Re: Cambelt cover
Here you go, thanks for your help.
